Hi All,
I see the following exception when i try to load the dashboard. Anyone can help me to fix this.
org.apache.shindig.gadgets.GadgetException: Unable to retrieve gadget xml. HTTP error 503
the reason may be gadget.xml file opening and closing tag mismatch or.
while loading dependency files or other entris with you gadget.xml are not available or having some probs.
so it is generating org.apache.shindig.gadgets.GadgetException exception.
The reason could be your proxy or webserver filters this content. The gadget will work if you use http or IP instead of your web url.
I also face this after upgrade. Couldn't fix this yet :(
