Exclude the custom field values using "!=" not working
Lakshmi S
October 21, 2024
Hi Team,
(issue.getAsString("Issue Type") == "Change Request" || issue.getAsString("Issue Type") =="Bug") && (issue.getAsString("customfield_10204") != "APAC Fulfillment Implementation" || "APAC Support" || "APAC System Automation Implementation")
When I try to exclude the custom field values (in the condition) to set the field in the workflow post function, the "!=" operator doesn't seem to work. Is anything making a mistake here?
Salih Tuç
October 21, 2024
The issue is in "OR" conditions in this block:
 For each value, you need to add "not equal" part to the left side:
(issue.getAsString("customfield_10204") != "APAC Fulfillment Implementation" || issue.getAsString("customfield_10204") != "APAC Support" || issue.getAsString("customfield_10204") != "APAC System Automation Implementation")
By the way (I didn't try but it should work since it is a Groovy condition), you can simplify this part as:
issue.getAsString("customfield_10204") not in ["APAC Fulfillment Implementation", "APAC Support", "APAC System Automation Implementation"]
Lakshmi S
October 22, 2024
HI @Salih Tuç ,
This is working as expected.
Like Salih Tuç likes this
