Execute method when jira recive a GET RESPONSE with parameters
Stefano Rosario Aruta
Hi i need help i need to make a script. I do not have i ide where i make this script.
i need that when i open this link:
http://localhost:8080/rest/scriptrunner/latest/custom/doSomething?issueId=10404&username=User13
i want that jira run a script where it execute a transition. Someone can help me?
 i make this script as ScriptRunner Rest Endpoint but it does not work:
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import groovy.json.JsonBuilder
import groovy.transform.BaseScript
import javax.ws.rs.core.MultivaluedMap
import javax.ws.rs.core.Response
//import com.atlassian.jira.user.util
@BaseScript CustomEndpointDelegate delegate
doSomething(httpMethod: "GET", groups: ["jira-administrators"]) {
MultivaluedMap queryParams, String body ->
def issueId = queryParams.getFirst("issueId") as String;
def userString = queryParams.getFirst("username") as String;
def issueGet = get('/rest/api/2/issue/' + issueId);
def issueService = ComponentAccessor.getIssueService();
//def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def user = ApplicationUser.getUser(userString);
def issueInputParameters = issueService.newIssueInputParameters();
def transitionValidationResult = issueService.validateTransition(user, issueGet.getId(), 11 as Integer, issueInputParameters);
if (transitionValidationResult?.isValid()) {
issueService.transition(user, transitionValidationResult);
return Response.ok(new JsonBuilder([Risoluzione: "Riuscito"]).toString()).build();
} else return Response.ok(new JsonBuilder([Risoluzione: "Fallito"]).toString()).build();
Marc Minten (EVS)
February 15, 2019
Hi, what do you mean with "it does not work" do you get error messages ? Do you see errors in the Jira log files ?
Marc Minten (EVS)
February 15, 2019
These are just static type checks. You can ignore them.
Groovy does run time type checking, and this will run correctly.
If you would get rid of these errors, you should declere your variables with the corerct type:
ApplicationUser user = ...
can you make a code override?
