Looking for ideas and report / templates to enable weekly senior executive level status reporting in Jira. We use Jira to organize and track development in several initiatives- the information is too granual for c-level leadership. We need a way to synthesis activity and progress in a given period, articulate whether we are ahead, on track or behind and why...as well as any blockers. Currently, we find we have to manually synthesize Jira information and then manually create executive level status in ppt. Would be great to generate this type of status in Jira. Ideas welcomed.
Hi @Christopher Sanders did you get a solution?
I have an add-on suggestion for you too. The add-on that I have created Simple Reports & Charts - https://marketplace.atlassian.com/apps/1218888/simple-custom-reports-charts-for-jira
It has an ability to subscribe to Overview report by an email weekly - so you get an overview pdf each week.
Why is it to get some simple freaking executive reporting for JIRA, we always have to go after more cost for a plug in to overcome the gaps of this product?
I believe we have exactly what you need :)
In our add-on Status History PRO you have possibility to prepare any kind of executive summary regarding status changes in current project. More details you can find in detailed instruction how to use Status History Viewer.
If you need similar report with information about work logged, please take a look at Worklog History PRO and its Viewer.
In case of any questions, please let us know, we'll be happy to help!
Lime Trees Support Team
I have a few questions;
To answer your query I would like to tailor it to your requirements. A few pointers from yourself would be helpful in fully understanding.
