Export Project Issues to Webpage
Wouter Spaans (Planning) October 25, 2016
How can I export an issue list from a project to a php/html website?
I want to make webpage that's shows only the issues from an specific project.
Thanks you!
Aleks Yenin (Polontech)
October 25, 2016
try to use REST API: /rest/api/2/search?jql=project="Your Project Key"
Thanks for reply!
And how can I use this in HTML or PHP?
Nic Brough -Adaptavist-
October 25, 2016
You'll need dynamic code (javascript or php) to actively issue a request to JIRA to give it the issues, then parse the result and reformat it for display.
Do you have some code or examples for me? I am not an proffesioneel php'er.
