Export Single Project
Mohin Uddin
Hi Expert,
How can I export single project from JIRA. Is there any way to export this?
Mohin
Mohin Uddin
Thanks for reply.
How can I export to import a single project?
Could you please let me know?
Mohin
Jobin Kuruvilla [Adaptavist]
September 17, 2014
Mik Scheper June 20, 2017
Thanks, Jobin, but the docs say to go to ⚙→System→Import & Export→Project Import, but the Import and Export menu in the instance I'm moving the project to doesn't have a 'Project Import' option. It does have a 'Restore system' option, but that says 'Please note that this process will delete all existing JIRA data in your site', which is definitely not what we want. Help?
September 16, 2014
Nope. You will have to export the whole JIRA. But you can use that export to import a single project, if needed.
Chad Wilhelm February 27, 2015
What kind of impact does exporting the whole system on a production system during heavy load?
