Export issue information to filesystem
Antonio D'Errico
Hi there,
i have following situation:
after i execute a transition X this issue should be automatically exported to a (for example) csv file and should be saved on the filesystem. the csv should have the current issuekey and severals cf.
how can i do this?
best
toni
Alexey Matveev
February 20, 2019
You would need a plugin for it.
For example, you could use the Power Scripts plugin.
You could create a post function in which you would create a file in the file system. You can find more information on how to create a csv file here:
https://confluence.cprime.io/display/SIL/createFile
