Sign up Log in
Extract Value from Custom Field and use it in jql ?
Claus köll March 13, 2013
Hi all ...
I have a custom field named "SLATime" and i write there values like -3h or -50m.
To the search question ...
Its already possible to find all issues with state open and created within the last 3 hours.
project = SD AND status = Open AND created >= -3h
I want now to search issues the same way but with the value of the SLATime field
project = SD AND status = Open AND created >= valueof("SLATime")
Is this possible ?
Thanks for any help !
claus
JamieA
March 13, 2013
If you used a numeric field for SLATime, eg 180 instead of "-3h", you could use the expression function in the script runner plugin. This is much harder than you probably think, JQL wasn't really designed for this kind of sql-like concept.
The query would be something like:
issueFunction in expression("project = SD and status = Open", "created > (SLATime * 60000) + today)")
But, I haven't really checked that and you would need to experiment a bit, not sure about the millisecond conversion there. You might want to consider writing your own jql function, either using this plugin, or not.
Register Now
Upcoming Jira Events
