Extract all the workflows in JIRA
Drishti Maharaj
June 22, 2021 edited
Is there a simple way in which we can extract all the workflows in JIRA and have complete list of them (including the diagrams) and stating to which project they belong to as well?
Vikrant Yadav
Hi @Drishti Maharaj There are so many methods to get Workflow, simplest way is to use REST :-
https://jira.xyz.com/rest/api/2/workflow/?$format=json
..covert json to csv.
OR
Use SQL query : - https://community.atlassian.com/t5/Adaptavist-questions/Sql-query-to-get-active-workflows-from-all-projects-in-Jira/qaq-p/590713
OR
you can use script runner script to get complete list of workflow.
but i dont think none of the method, inculde diagram of the workflow.
Drishti Maharaj
@Vikrant Yadav , thank you - I will try these and to see how it works.
Like • Vikrant Yadav likes this
Andre Serrano
June 22, 2021
You can use Microscope (https://marketplace.atlassian.com/apps/1225065/microscope-power-audit-for-jira-admins?hosting=datacenter&tab=overview)
to list all Workflow Functions created by apps.
The outcome will be a CSV file listing all Workflow functions, which apps created those workflow functions, which workflows these functions belong to, the Workflow status, etc.
Drishti Maharaj
Hi @Andre Serrano , thank you for that but seems I cannot add anything to the JIRA instance due to licensing problems...
