Hi All,
I am using the following Groovy script to extract last modified by username. However when I select Text field as the Template I get the username but when I select User Picker Template I get Anonymous. I need the full name to displayed and not just the username.
changeItems = componentManager.changeHistoryManager.getAllChangeItems(issue) if (changeItems?.size()> 0 ) { componentManager.userUtil.getUserObject(changeItems.sort( false ).last().user) } else { null } |
Can you try the following code?
import com.atlassian.jira.component.ComponentAccessor def changeHistoryManager = ComponentAccessor.getChangeHistoryManager() def changeItems = changeHistoryManager.getAllChangeItems(issue) if (changeItems?.size() > 0) { def userUtil = ComponentAccessor.getUserUtil() def userkey = changeItems.sort(false).last().getUserKey() userUtil.getUserByKey(userkey) } else { null }
The User Picker template expects com.atlassian.jira.user.ApplicationUser instead of a com.atlassian.crowd.embedded.api.User.
Hi Alejo,
I am still getting the same output with the new script. Anonymous for User Picker Template and username for Text Field Template.
I just edited my answer. The code was returning the user name while it should have returned the ApplicationUser instead.
Bear also in mind that if the field uses the User Picker template, it will appear on the right hand side of the issue screen, under the People section.
Help us plant more trees
