Dear all,
we have a quite complex setup at the customer
and nothing has been documented, like, ever...
Is there an easy way (a plug-in for example) to extract
all of the workflow mappings of all the projects (300+)
straight into Confluence (or Excell for that matter)?
You would save us an enormous amount of time...
Best regards and thanks,
ST.
Not that I know of - I found a page on locating the diagrams in the database which might be useful - see this page.
For managing configurations, you could look at whether an app such as Project Configurator can export the data you need in a usable way, but it isn't designed for what you need specifically and not something I've tried.
When I've needed to document designs, I did it in Confluence - I at least built a template first that we populated and then worked through for each workflow.
Ste
Hey @Ste Wright
thanks for the answer,
I'll look into Project Configurator first thing if I'm at the client...
Best regards,
ST
Dear @Sander Theetaert ,
What if i say you can fully document a single project with 1 click (to PDF or Confluence)? :)
Glass Project Documentation does this for you.
Currently it is designed to make an export from project perspective!
Contact me if you have more feature ideas!
Balázs
