×I have installed Jira and stopped auto setup in between as it was taking lot of time
But now I am not able to access jira as need to set up manually
Hi Nitin,
Please first check if JIRA is actually running:
https://confluence.atlassian.com/jirakb/how-to-check-the-jira-application-is-running-794499415.html
If it's not running please start it manually:
https://confluence.atlassian.com/jirakb/jira-application-startup-and-shutdown-scripts-653951272.html
Once JIRA is started up you should be able to access it (if default is used): http://localhost:8080
If you are facing issues after JIRA is started; please provide the last entry of the logfile: $JIRA_HOME/log/atlassian-jira.log
E.G.
**************** JIRA starting... ****************
line1
line2
etc...
Please let us know how it goes.
Steven
