Sign up Log in
Facing issues while building skeleton for Jira Plugin Development
Avinash Gautam
i Team,
I am trying to learn plugin development by following below link:
https://developer.atlassian.com/server/framework/atlassian-sdk/run-your-plugin-in-the-container/
I am using the command to build the "/test" path in jira. But i am facing
[ERROR] Unresolveable build extension: Plugin com.atlassian.maven.plugins:maven-refapp-plugin:6.3.13 or one of its dependencies could not be resolved: Failure to find com.atlassian.maven.plugins:maven-refapp-plugin:jar:6.3.13
in https://repo.maven.apache.org/maven2 was cached in the local repository,
resolution will not be reattempted until the update interval of central has elapsed or updates are forced
in pop.xml file. The dependencies mentioned in the AdminUI project at pom.xml location is showing above error while running it. Could you please help me as i have tried everything but it is not working.
Also let me know if you can help with updated commands to learn plugin development as i see the mentioned commands are quite older and sometime does not execute with certain JIRA versions.
Timothy
January 28, 2018
Avinash Gautam
Hi Chin,
I am not sure why the project is looking for the that version of maven plugin. I see Capture1.PNG
Please let us know why this plugin need this package. This is completely build with Atlassian Commands for plugin skeleton creation.
--Avinash Gautam
Timothy
January 30, 2018
That is the package used by the amps-xxx build plugin to package the code.
