Failed standalone jira server during "plugin system earlystartup"
Tareq Mohammad Yousuf
October 22, 2018
2018-10-22 09:54:18,677 JIRA-Bootstrap INFO [c.a.plugin.manager.DefaultPluginManager] Plugin system earlyStartup begun
2018-10-22 09:54:40,751 http-nio-8080-exec-2 ERROR anonymous 594x1x1 g7xs99 116.68.200.58 /favicon.ico [c.atlassian.instrumentation.Instrument] Unable to snapshot thread local operations (implementation of OpTimerFactory is not a ThreadLocalOpTimerFactory): null
2018-10-22 09:54:52,615 ThreadPoolAsyncTaskExecutor::Thread 13 WARN [o.s.b.factory.support.DefaultListableBeanFactory] Overriding user-defined bean definition for bean 'jiraAuthenticationContext' with a framework-generated bean definition: replacing [Generic bean: class [com.atlassian.jira.security.JiraAuthenticationContext]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Root bean: class [org.eclipse.gemini.blueprint.service.importer.support.OsgiServiceProxyFactoryBean]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
and later
2018-10-22 09:55:12,921 JIRA-Bootstrap INFO [c.a.plugin.util.WaitUntil] Plugins that have yet to be enabled: (63): [com.atlassian.jira.plugins.jira-post-upgrade-landing-page-plugin, com.atlassian.jira.jira-header-plugin, com.atlassian.gadgets.dashboard, com.pyxis.greenhopper.jira, com.atlassian.jira.jira-core-reports-plugin, com.atlassian.jirawallboard.atlassian-wallboard-plugin, com.atlassian.applinks.applinks-trustedapps-plugin, com.atlassian.jira.plugins.jira-importers-trello-plugin, com.atlassian.plugins.base-hipchat-integration-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jira.project-templates-plugin, com.atlassian.applinks.applinks-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jirafisheyeplugin, com.atlassian.troubleshooting.plugin-jira, com.atlassian.applinks.applinks-cors-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.applinks.applinks-oauth-plugin, com.atlassian.plugins.atlassian-whitelist-core-plugin, com.atlassian.plugins.atlassian-remote-event-consumer-plugin, com.atlassian.webhooks.atlassian-webhooks-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.jira.plugins.jira-optimizer-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.gadgets, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.plugins.atlassian-remote-event-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.jira.plugins.jira-importers-github-plugin, com.atlassian.jira.plugins.jira-importers-bitbucket-plugin, com.atlassian.jira.rest, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.jira-quick-edit-plugin, com.atlassian.plugins.base-hipchat-integration-plugin-api, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.jira.jira-issue-nav-components, com.atlassian.analytics.analytics-client, com.atlassian.jira.jira-projects-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.jira-mail-plugin, com.atlassian.streams, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.gadgets.embedded, com.atlassian.jira.plugins.jira-software-plugin, com.atlassian.plugins.authentication.atlassian-authentication-plugin, com.atlassian.whisper.atlassian-whisper-plugin, com.atlassian.jira-core-project-templates, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.actions, com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.jira.jira-projects-issue-navigator, com.atlassian.applinks.applinks-basicauth-plugin], 281 seconds remaining
Killed
please help. thanks
Andris Grinbergs
October 22, 2018
Try waiting longer (do not kill/stop java/jira)
Ensure you have enough RAM,
Disable selinux
Temporary - try starting Jira as root with (.../bin/start-jira.sh)
October 24, 2018
Thanks for the reply. i had to increase RAM. from 1GB to 2GB
Like Maxim Maximov likes this
