Failed to close an issue
PaulaA
Hi all,
On a shared workflow, when a user tries to close an issue the error message "Issue is not closed" appears. He's the reporter and the assignee so he's supposed to be able to accept all changes and proceed. He can also change statuses, that works. It only happens to one user and the project hasn't changed. Any ideas?
Vasiliy Zverev
January 9, 2019
It seems that there is trouble with validation.
Check all validators for this transition.
PaulaA
Hi @Vasiliy Zverev
For this transition I have the default post functions, 1 condition (fulfilled by the user), no triggers, no validators.
It has to be something else but I'm pretty lost. Any other ideas?
Vasiliy Zverev
January 9, 2019
It could be permission issue. see @Fazila Ashraf last answer.
PaulaA
No, I double checked with the permission helper and manually. It's not that
Vasiliy Zverev
January 9, 2019
Try to investigate jira-log.txt for errors.
Fazila Ashraf
Hi @PaulaA
Could you look at the jira logs for more information?
Also check the workflow transition for validator and postfunction to see whether any of them could cause this problem.
PaulaA
Hi @Fazila Ashraf
To close the issue we have only one condition that the user fulfill and the postfunctions are also correct.
On the logs I cannot find anything that helps me to understand the issue
Fazila Ashraf
Did you validate whether the post functions are executed before the error appears?
PaulaA
How do I do it? The postfunctions are the 5 that all JIRA and one adding a comment.
In any case, the workflow is shared by many projects and only this user has this problem
Fazila Ashraf
Well, if the post functions are all the default jira ones, it might not be that.
Please check whether the user is able to close another issue in the same project.
Could you check whether the user has 'Transition issue', 'Close issue', 'Resolve issue' permissions in the project's permission scheme?
Can you give him a higher access and check whether he is able to?
PaulaA
he has as much permissions as possible. He's an project admin, he can edit, delete, create, move,... issues. It's really a special case because he's the only person facing this issue for this workflow (shared in many projects).
I checked with the permission helper and he has the permission to close issues... it's really strange
Fazila Ashraf
And he is able to close another ticket successfully in the same project?
Could you try a project reindex?
