Hi Guys,
I am trying to create RefApp plugin skeleton in jira . I run the command atlas-run after doing modifications to the atlassian-plugin.xml and pom.xml file. This Plugin launched on port 2990. but, when i clicked on add-on's--> Manage add-on's the plugin modules are not enabled. I'm trying to enable it but it is showing the error "This add-on failed to enable.Refer to the logs for more information". Where can we find these logs?
Vikram
Hi Vikram,
You'll want to look in the JIRA_HOME/log/atlassian-jira.log and the JIRA_INSTALL/logs/catalina.out for futher information.
Branden
