Dear friends,
i am unable to import using CSV and slecting the option "Project information contained in CSV file"
i am getting this error :
I already created these products (Website,NBID,MCP,DSS) and now i want to add the old database using CSV
is the option "Project information contained in CSV file" doen t work with existing Products (or existing Project Key)?
thank you for any help or workarround
I think you are facing this bug in JIRA Importers plugin. It is a regression which is now fixed in JIM 3.2. Feel free also to use a snapshot version attached to that issue which works with JIRA 4.3.x.
Wojtek
thanks for your help.. I will try it asap
please paste me the download URL link for JIM 3.2
Yes i have the same problem ..i will try to use JIM 3.2
Hi, JIRA Importers Plugin has its PAC page at: https://plugins.atlassian.com/plugin/details/32645.
Download link to 3.2 is: https://maven.atlassian.com/content/groups/public/com/atlassian/jira/plugins/jira-importers-plugin/3.2/jira-importers-plugin-3.2.jar
sorry for my late reply , i have been solving other probems
anyway I am using jira 4.3.4 i downloade jira imported plugin 2.7.6 and it didn t work
is the 3.2 compatible with jira v 4.3.4 ?
Hi I am sorry for my late reply
I am using this version JIRA 4.3.4 and downloaded jira-importers-plugin-3.2
but i can not see external system import in The Import and Export on the left pannel
seems it is not compatible with Jira 4.3.4
what do you suggest?
JIM 3.2 works only with JIRA 4.4.x. However we have a snapshot version of 2.7.6 with this bug fixed too - please take a look at https://studio.atlassian.com/secure/attachment/16523/jira-importers-plugin-2.7.6-SNAPSHOT.jar (an attachment to aforementioned issue)
I used several csv (group by many projects) . i tried all plugins but didn t work..
anyway I think it s a bug and fixed as you mentioned
