Contrary to the similar questions/answers in this database, I am not developing a plugin etc., merely try to restart a JIRA instance that had been upgraded from version 4.4 to version 5.2 a number of months ago (using live update functions, not installing new version and upgrading database). I believe this is the first time the JIRA instance has been restarted and I'm getting :
The data present in your database is newer than the version of JIRA you are trying to startup.
Database version is: 812
JIRA app version is: 589
Please use the correct version of JIRA. You are running: 4.2.2-b589#589
Also strange to me is that it's claiming version 4.2.2 rather than the 4.4 I know was previously running.
So how do I force the 5.2 version of JIRA?
Thanks, Scott
So it turns out that one of the JIRA startup processes couldn't bind to local port 8005 and therefore threw the whole startup into some sort of hissy fit - discovered by going through catalina.out log file.
Identified the process that was holding onto port 8005 with
sudo netstat -ltnup
manually killed the process and restarted jira => no more problem(yet no explanation as to why it was claiming version mismatches)
*WOULD CERTAINLY BE NICE* to have more accurate details appear in the browser window when JIRA can't start
Thank you to Ricardo for responding quickly!
That link no longer works. It has been changed to this: https://confluence.atlassian.com/display/JIRA052/Incorrect+database+type+specified
Thanks for quick response but there is nothing defining the database within either of those config files.
I'm starting JIRA via command line on Ubuntu server and when I do, it displays the ASCII art JIRA logo and
Atlassian JIRA
Version : 5.2
Detecting JVM PermGen support...
Additionally, looking at the tail of the atlassian-jira.log, I see today's entries confirming version 5.2 but don't understand the implications of the error that follows:
2013-07-15 17:06:44,705 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
JIRA 5.2 build: 812 started. You can now access JIRA through your web browser.
2013-07-15 17:06:44,864 localhost-startStop-1 INFO [atlassian.jira.upgrade.UpgradeManagerImpl] Setting current build number to 812
2013-07-15 17:07:07,746 QuartzWorker-1 ERROR ServiceRunner PluginLicenseExpiryJob-job [atlassian.jira.service.ServiceRunner] An error occured while trying to run service 'PluginLicenseExpiryJob-job'. PluginScheduler job 'PluginLicenseExpiryJob-job' is expected to exist but it doesn't
java.lang.IllegalStateException: PluginScheduler job 'PluginLicenseExpiryJob-job' is expected to exist but it doesn't
Save your spot
