Fast-track transition - Condition on Subtasks
Alexander Richter
May 8, 2019
I'm using the Scriptrunner - Fast-track transition function in one of my workflow transition. The function should only fire , if all subtasks are resolved.
Can somebody give me a hint how the code should look like?
i searched a bit for myself and had following solution
def subTasks = issue.getSubTaskObjects()
subTasks.each {
if(!issue.getResolution()){
false
But the function will fire nevertheless :(
Christos Moysiadis
May 8, 2019 edited
def countResolved = 0;
subTasks.each { sb ->
if(sb.getResolution() == "Resolved"){
countResolved++
if(countResolved == subTasks.size()){
return true;
return false;
Something like this? I have not tested it.... sorry if there are any errors
PS: i'm sure there is a better solution too.
Alexander Richter
May 8, 2019
Hi Christos,
there are no errors in it ;-)
But with your code the function is not firing at all. Though all subtasks are resolved, the transition is not happening.
Christos Moysiadis
May 8, 2019 edited
maybe because they are all already resolved ?!
I have not used this fast transition option to tell you the truth. We use a custom listener for some specific automatic transitions
Alexander Richter
May 8, 2019
would that make sense? :-D
maybe i should try the custom listener instead...
Christos Moysiadis
May 8, 2019 edited
For some reason i am sure that it should work @Alexander Richter :D ... maybe the post function (fast transition) is in wrong transition step, between status A and B, while it should be inbetween C & D etc.
Did you check these details? Sometimes the solution is in front of our eyes and we doesn't see it!
Like Alexander Richter likes this
Alexander Richter
May 8, 2019
@Christos Moysiadis  i am sure it is somewhere in the details :-)
but it is not about the transition, this one works.. when i leave the condition blank it will Transition the issue as i want it to do. It has to be the condition.
At first i tried to go for the status with following code:
subTasks.each {
issue.getStatus().getName() == 'Active User'
what it does is that the issue will be transitioned if one of the subtasks has the right status. If all other subtaks do not have the right status the function will fire nevertheless.
So i am not really convinced that subTasks.each{} is doing what it should do... on the other hand i am a scripting noob and maybe just think wrong :D
just right now i changed your code from == "Resolved" to != "Unresolved" .. Now the function will again fire every time instead of not at all :D
Christos Moysiadis
May 10, 2019 edited
@Alexander Richter hi again... I knew that , there is something like you wanted!
How about this: 1. test1.png  2. test2.png test2.png
As it says.. it will close the parent issue when all the subtasks are resolved.
regards
CM
Alexander Richter
May 13, 2019
Hi @Christos Moysiadis , thanks for sharing but that won't help in my case.. :-(
using the postfunction you mentioned above, the parent issue will be transitioned as soon as the last subtask is resolved.
I need the condition to be checked while transitioning the parent task from step A to step B. if it evaluates to true step B shall be skipped.
So fast track transition would be exactly what i need, if i got the condition running...
