Hi. I am trying to count number of bugs which are reported every week in specific projects with JQL (I am not sure how to get count only). and then I want to get this number in excel, so that I can see how many bugs have been reported, in comparison to last week, last month, last year. And I am drawing excels graphs using that data. Excel is storing my data and drawing graphs for me but I need to have data from JIRA automatically based on filters, I apply.
So I need counts of bugs in projects (not bugs), historic data and how to fetch them directly from excel so that I don't need to go to JIRA. I trying to automate my reports. We have JIRA version 6.4.9
I hope I am able to describe my question and now waiting for response.
Thank you.
Hello Everyone,
Several teams have interacted In this thread for the past few years, so here is an updated answer for everyone interested in this matter:
Atlassian has deployed some solutions to manage Jira Cloud issues directly from Excel or Google sheets and provide an easier way to build reports integrating both applications. You can check below the two free apps that provide this functionality:
Jira Cloud for Google Sheets official
With the end of sale for Jira server, we are not planning to develop any official integration option that provides this integration, however, there are some third-party vendors that provided some paid solutions to achieve the same goal. You can check our Atlassian marketplace for some available options:
https://marketplace.atlassian.com/
Community moderators have prevented the ability to post new answers.
See here for the official Jira Cloud to Excel export: https://marketplace.atlassian.com/apps/1221301/jira-cloud-for-excel-official
This plugin supports JQL from within Excel via the new Jira() function.
My initials tests with the new plugin works. Sort of.
I am still unable to get the parent reference for any subtasks no matter what I do. The data is definately there because I get the data when I query the API directly.
Any one else has this experience?
I cannot find the documentation about the JIRA.JQL() function. I saw yesterday some examples but I closed the page and cannot find it anymore.
It should be linked to the support tab of the addon.
Found that from the "Find Examples" link here:
Hello Everyone,
You can easily and automatically import Jira Cloud data directly into Excel by following these steps:
1. Create a filter view in Jira with all of your desired columns, save it, and make a note of the path. Example: https://mycompany.atlassian.net/issues/?filter=11940
2. Change the path to https://mycompany.atlassian.net/sr/jira.issueviews:searchrequest-csv-current-fields/11940/SearchRequest-11940.csv
Note that going to this URL in your browser returns a CSV file.
3. Start Excel, and select Data menu, New query, From Other Sources, From Web
4. A dialog will appear asking you for the URL. Paste in your CSV URL from step 2, and click OK
5. You will be prompted with a permissions dialog. Select Basic authentication, enter your Jira username and password, and click Connect.
6. After Excel connects, you will see a dialog with a preview of the table. Click Load to load it into the current worksheet.
From this point forward, your Jira credentials will be cached, and you can update the query at any time by clicking Data/Refresh all.
This is exactly what I needed. I had been downloading the CSV, putting it into a folder and connecting to it that way. It never occurred to me that I could directly link Power Query to JIRA through a Web data connection. Brilliant! This saves me a huge amount of time.
If you enter you credentials wrong or need to change them, it's not easy to find as you're not prompted again after entering them. Here's how to fix it. I'm using Excel 2016 (Office 365):
Hope that helps and thanks for the info!
The path does not seem to work with JIRA v6.4.13. My filter is in the format: https://mycompany.atlassian.net/jira/issues/?filter=39787
would someone know the corrsponding CSV path?
I tried various choices like https://mycompany.atlassian.net/jira/sr/jira.issueviews:searchrequest-csv-current-fields/39787/SearchRequest-39787.html but no luck.
searchrequest-printable works but it creates 2 rows if I include the labels column so wanted to try CSV.
The URL's have not changed for me. Not sure why your path is different. The way I determined the CSV path was by looking at the network traffic in Fiddler when I clicked the link to download a CSV of the report. You can use the same technique.
Thanks I don't see an option to download csv files in the jira instance we have. Perhaps it has been disabled.
Peter,
Your URL needs to have .CSV at the end of it instead of .HTML .
From reading other people's posts, the export to .csv option is no longer enabled by default, your company's JIRA admin would need to enable the option.
I've also tried to fetch data from the export xls. option, and it does not work.
Nope, wrong. Export to CSV is fully enabled in all all Server versions of Jira, and still available on the last Cloud system I looked at a couple of minutes ago.
What are you looking at?
Hi Guys, Me too trying the same. But i am getting error as "The command you selected is not available from this shortcut menu." while clicking import option. But using the URL i am able to download the csv successfully.
Steps followed:
Please help me in this
That's not a native Jira message, which suggests an add-on is in use. I'd look at the docs for that (If you don't have access to something in Jira, it hides it, not blocks it after selection)
Did you find the solution to this problem? I am also running into the same error.
I am having an issue with this as well, but I am not getting an error. My power query in excel is setup correctly and I can successfully pull the same CSV from other URLs, but when I try to connect to Jira the data does not populate; the preview always shows up empty.
Above it was mentioned that I should not be blocked by any permissions, but I believe that there is some authentication issue at hand and I can't figure it out.
Below are the steps I used in detail:
From here, the preview window was showing up empty so I made sure that I had the correct permissions set by doing the following:
Any insight on how to resolve this problem?
i'm following the same steps, but in the preview is showing HTML code instead of the CSV information, if i go to the link https://mycompany/jira/sr/jira.issueviews:searchrequest-csv-current-fields/51155/SearchRequest-51155.csv the CSV is downloaded correctly and without any issues, but when i copy that link to the power query option in excel it returns HTML code, does anyone knows how can i solve this?
thank you.
@Ken Parry i'm having the same issue doing this:
is there an specific position i need to add the "?" ?
The ? is at the end as you show..
make sure you are using:
Select: New Query->From Other Sources-> From Web
Then I have :
File Origin: 65001: unicide (UTF-8)
Delimiter: Comma
Date Type Detection: Based on first 200 rows
Hope this helps
I was having problems even getting it to download from the URL. I went back to the app and did a right click on the download as CSV link and found that there was a limit added to the end of the URL in Jira. I guess you can't download more than 1000 rows at a time (certainly when I tried 2000 it didn't work).
?tempMax=1000 was appended to the URL:
The solution suggested at the top of this post works for me. I used basic authentication and specified my credentials. But when the excel file is shared with other team members, the import operation fails with following message in excel when the member tries to refresh the excel table : "Initialization of data source failed. Check the database server or contact your administrator. Make sure the external database is available, and then try the operation again. If you see this message again., create a new data source to connect to database." The same operation works on my machine. Please suggest possible solution.
Did you passed your credentials as well?
I understand the filters are available only to the user that created it, unless it has been shared.
The Method for connecting Excel to a Jira Cloud instance has changed slightly.
You now have to generate and use an API Token as the password, rather than your normal password.
https://confluence.atlassian.com/cloud/api-tokens-938839638.html
https://id.atlassian.com/manage/api-tokens
Update of Dave's original instructions:
Change your Data source settings with ur jira username and password, it will work.
It will be using anonymous currently
-Yamuna
I am able to follow first set of instructions and I got the result in excel by using my project jira board.
But if user enters invalid credentials then there is 2 nd set of instructions as:
As I am using Excel-2013 so Power query is not there. I have installed it successfully and now I am able to see it. But as mentioned in step 2 you will see list of data sources but for me this is showing as blank
Please provide me resolution as I got stuck between this..
Thanks!!
Seems Basic Authentication is not working from excel, what could be reason.
Hi Nilesh. Did you check out this article?
You might need to set up a token now.
Used Get Data from Web and able to preview the Jira data just yesterday. But when I attempt today and click on Load, I get an error that I am not authorised which seems odd since the data is showing in the preview. Any suggestions?
By using the API way, it works fine. For me... No one else in my team can refresh the data but myself. The filter is open (and they can access it) and they have access to the location where my excel file is stored (Sharepoint).
Any ideas on how to make it work for all?
For those who
you can get the same CSV results exporting all available fields as documented above by using the following URL structure, which includes a JQL query parameter:
https://mycompany.atlassian.net/sr/jira.issueviews:searchrequest-csv-all-fields/temp/SearchRequest.csv?jqlQuery=
and, as mentioned above, you can also choose to export only the set of fields currently displayed in the Jira user interface:
https://mycompany.atlassian.net/sr/jira.issueviews:searchrequest-csv-current-fields/temp/SearchRequest.csv?jqlQuery=
Atlassian discontinued the basic authentication using email + password, but it's possible to log in using an API token.
Steps:
Log into Jira and go to https://id.atlassian.com/manage/api-tokens
Generate a new token and give it any name you like. Copy it (once it is generated and saved, it cannot be viewed again. If you forget it, you'll have to create a new one).
In power BI, paste the generated token in place of the password, in the "Basic authentication" tab.
The connection will be sucessful now.
Hi all,
A lot of comments bout using CSV. I've actually followed very similar step but am using the APIs instead. MUCCCHHHH better. The data is much richer and you don't run into troubles when importing fields that are multi-select. In CSV, multi-select field come up in separate columns which you might not be able to predict so you transform logic become fragile.
Here's what I did... very similiar to the CSV version.
Importing into Excel Using Jira APIs
let LoadJiraIssuesFn = (startAt as number) =>
let
Source = Json.Document(Web.Contents("https://mycompany.atlassian.net/rest/api/3/search?jql=project%3DDIG%20and%20issuetype%3DBug&fields=issueType,summary,assignee,status,created&maxResults=100&"&Text.From(startAt))),
issues = Source[issues],
#"Converted to Table" = Table.FromList(issues, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
#"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table", "Column1", {"key", "fields"}, {"key", "fields"})
in
#"Expanded Column1"
in LoadJiraIssuesFn
let
// load all the records (this is will only load 200 records unless I make the call a few more times)
Source = Table.Combine({#"LoadJiraIssues"(0),#"LoadJiraIssues"(100)}),
#"Filtered Rows" = Table.SelectRows(Source, each true),
// Expand out the results to get the data
#"Expanded fields1" = Table.ExpandRecordColumn(#"Filtered Rows", "fields", {"summary", "assignee", "created", "status"}, {"fields.summary", "fields.assignee", "fields.created", "fields.status"}),
// Expand out some of the fields to get display names
#"Expanded fields.assignee" = Table.ExpandRecordColumn(#"Expanded fields1", "fields.assignee", {"displayName"}, {"fields.assignee.displayName"}),
#"Expanded fields.status" = Table.ExpandRecordColumn(#"Expanded fields.assignee", "fields.status", {"name"}, {"fields.status.name"}),
// Rename the column because I'm OCD
#"Renamed Columns" = Table.RenameColumns(#"Expanded fields.status",{{"fields.summary", "Summary"}, {"fields.assignee.displayName", "Assignee"}, {"fields.created", "Created"}, {"fields.status.name", "Status"}, {"key", "Jira Id"}})
in
#"Renamed Columns"
(Thanks Dave Ahlers for the CSV tips above - I unashamedly based this on yours! Thanks mate - this really helped!)
Some other things to note:
With this method I've been able to produce reports like this in Excel really quickly that also update with the press of a button. They look much nicer than what I can do in Confluence and no plug-ins required.
I'm using Excel 2013. I couldn't find "Data menu, New query, From Other Sources, From Web". So, I use "Data menu->From Web" directly, which pops up a window called "New Web Query". I pasted the cvs file path
into the address field. There is no place to choose "Basic authentication". Only button "GO" and "Import", which pops up a window asking me to either open or save.
Is that something related to permission, excel version, or I don't have something needed on my machine? Thanks!
I use Power Query which is built into Excel 2016, but you have to install it separately for Excel 2013:
Thanks @Brendan Walker This is exactly what I needed. Had some trouble getting it to work in Excel though, but managed to get it done.
Maybe I should just explain my trouble at bit more. It turns out the original query miss the startAt parameter. It only sets the value leading to always loading the same 100 issues no matter what value startAt has. My version is below with the changed section in green box.
Hello ,
Does anyone know how to use this steps to fetch the data as excel in Excel 2016. I get an error "External Table is not in expected format" when I tried to use this link in the power query.
https://mycompany.atlassian.net/sr/jira.issueviews:searchrequest-excel-current-fields/11940/SearchRequest-11940.xls
The reason why I need this is because certain fields like asignee / owner etc get converted to windows id of the organization instead of pulling the name. Otherwise csv does the trick in most cases.
Use the Better Excel Plugin that makes creating this report easy:
If you have the working template, you can refresh this any time using the latest issue data.
When I put the given path into a browser, I get the CSV file: https://mycompany.atlassian.net/sr/jira.issueviews:searchrequest-csv-current-fields/11940/SearchRequest-11940.csv
When i set up the web query in Excel, I get HTML code in the columns and only a single row of data.
My hypothesis is that it's caused by my company's Single Sign-On. When I log in to jira, I put in my work email and it then takes me to a SSO page to re-enter my log in info. I believe that my credentials are not making it to that second sign on page or are not getting accepted. Any ideas?
Adrian, I reckon I've just bumped into the same problem. We just converted to SSO via Cloud and I now can't access these URLs from Excel anymore.
+1 on any ideas?
Unfortunately, I run into the same problems as Adrian Galarza. When connecting through query in Excel, I get HTML code (e.g. <!DOCTYPE.html> etc. and further down meta-names and javascript-code. In addition, no real data from JIRA is imported. Does anybody know how to configure the query correctly?
So I got it working again. The cloud APIs don’t use the SSO credentials. They still link to the old password stored on Jira servers.
Problem is if this has expired the teams can’t reset it without contact the admin - fortunately I am one.
Either way I got it working again and now have some great looking dashboards in Excel without the need for any fancy plugins - just Jira APIs and Power Query.
Happy to share if anyone is interested.
Brendan, nice job getting it working! Please do share how you did it. (I'm not a programmer, but might be able to get some help here at work.)
we finally got it up and running. There is a strong need to reset the access to login-type=standard (not windows!!!) and set username/password. Data then was importing correctly to PowerQuery in Excel.
The first row has to be configured as header-row and several headers had been modified. In addition, the type of some attributes had been adapted (e.g. original estimate, time spent and remaining estimate to type=number, etc.).
Unfortunately, times are not available in detail but consolidated per issue. This is not useful for our needs. Does anybody know how to get a detailed list for reported hours per user, per day etc.?
Edit ur data source settings
Any ideas on how to make it work?
Answer from Dave Ahlers above worked for me after I used Fiddler to get the exact query "https://MyCompany.atlassian.net/sr/jira.issueviews:searchrequest-csv-all-fields/12345/SearchRequest-12345.csv?" _ I was then able to use the query editor to remove the columns that I did not want... Thanks so much!
I am a novice on using JIRA and have only basic understanding of Fiddler. Could you help me with a couple of hints on how you used fiddler to capture that URL, please?
Appreciate the help
Sujit
You could just enable develop console and view the console to see what the sent code is.. for instance in Chrome it's Ctrl+Shift+I to enable - look for the Console Window
Thank you, Ken.
I had got distracted :-) when I could not make progress with this. Will try again.
SQL for JIRA is a standard SQL API for reporting on JIRA with support for SQL aggregation functions like COUNT, SUM, etc. It also supports JIRA JQL, therefore you can execute:
SELECT COUNT(*) FROM ISSUES WHERE JQL = 'project=MYPROJECTID and type = Bug'
The database SQL query above will execute the JIRA JQL query and count the number of issues returned.
You could write a small Java program to save the results in a file with CVS format, for instance.
SQL for JIRA is really powerful add-on and it would be able to provide all the data sequence at once (all the bugs for a project grouped weekly for a period of time).
SQL for JIRA can be integrated seamlessly with Birt Reports for JIRA if you want to create a nice chart graph and display it on a JIRA Dashboard.
In this way, you would be able to see the graph up to date on JIRA itself at any time.
As Jeff suggested above:
Sub FollowJIRAQuery()
Dim QueryString As String
QueryString = "https://jira/sr/jira.issueviews:searchrequest-csv-current-fields/99999/SearchRequest-99999.csv"
ActiveWorkbook.FollowHyperlink QueryString
End Sub
Will open the results of query 99999 directly into Excel. Again, you need to be logged in first.
Has anyone successfully been able to fetch data from Jira to Excel in the current 2020 version of Jira Software Cloud with either the CSV file or Cloud API method not using any add-ons?
TIA,
Dan
Cheap and dirty method here.
You can embed the URL that downloads the csv as a hyperlink an Excel cell. Then use VBA to execute that link. You would need to have already logged into JIRA through your web browser.
Range.Hyperlinks.item(1).Follow
Put in a do while loop that then waits for the file to open in Excel. The ActiveWorkbook.Name will match the csv name you provided in the url. I recommend you include a wait time threshold and prompt the user to keep waiting if there is no response in 10 seconds or so. Once the file is opened, use code to automate what ever task you are interested in completing in Excel.
Firstly, thank you all for the information above. It was exactly what i was looking for. I am using the power query to download the JIRA data and then using pivot tables to create a dashboard, i have also added a macro refresh button.
My next hurdle is to set up the source data download so that anyone who opens the dashboard in the company can refresh. Is it possible to change the credentials from basic to anonymous by adding the API key to the source URL code? I have done this in the past by adding "&key=XXXXXX" with another ticketing system and it worked well.
A
If you've got your own JIRA server and an older JIRA version you can try
"https://<my jira server>/sr/jira.issueviews:searchrequest-excel-current-fields/11940/SearchRequest-11940.xls"
this document is useful. However, I met "forbidden" error when export result over 1000. Is there any solution to export result over 1000?
Please see the discussions above.
Is there a way to achieve fetching data from JIRA JQL into spreadsheet by using VBA? I have Excel 2013 that does not have Power Query. I am afraid it is a workstation and therefore I am unable to download the dll from M$oft.
Created an account just to share this comment. :)
Found this discussion to be very rich, diverse, informative, and polite.
Thank you all for your contributions.
I implemented the solution using PowerQuery with the URL containing the CSV link and basic authentication. While it works well for me, ideally I'd like to authenticate using the credentials of the user opening the Excel workbook. But, that's a task for later.
Need some help on getting the link to work. Modifying the
"//mycompany.atlassian.net/sr/jira.issueviews:searchrequest-csv-current-fields/11940/SearchRequest-11940.csv"
Link and posting it into a web browser opens the data in Excel as desired.
When I use the same link in Excel "Get Data" wizard as described in the post, the wizard preview show lots of blank rows with a few XLM objects (<!DocType html>. <head>, <meta charset=...>.
Any suggestions on how to resolve?
Astidis. had the same problem. I manage to make it work by changing the permission.
From where you are on your screen shot, click on edit..
In the Power Query editor window, do the following:
Hey, are you able to have the data actualized every time or you need to regenerate a new excel report every day? Thanks !
I actually have a VBA script that refresh the data at a click of a button.
Jocelyn, send the code please :)
Hi Luca.
You can call the refresh with this:
Worksheets("[Sheet name where your backlog was originally loaded]").ListObjects(1).Refresh
The sheet needs to be selected first.
This is my specific code
Set wsBkl = Worksheets("Backlog")
wsBkl.Select
wsBkl.ListObjects(1).Refresh
But where is the code to pull the issue table ?
Hi Luca, there is no code to initially pull the table. You have to create your query in Jira then set it up in Excel into a worksheet. My code is only to refresh whenever needed.
The original set up is describe several time in this post. I'm not gonna pollute the post with another copy of it. You can look at Dave Ahlers post form Dec.13 2017 for that
I followed what @Jocelyn Menard proposed of changing the permission. Still i am getting XML output. Now able to get data in CSV format
this is my URL , https://agile-jira.myCompany.com/sr/jira.issueviews:searchrequest-csv-current-fields/65419/SearchRequest-65419.csv
Using excel 2010
Any suggestion how to resolve
getIssueList from JIRA Command Line Interface (CLI) produces a CSV file that can be imported into Excel.
You'll probably be able to find some reporting add ons in the marketplace:
For example:
Timothy, A new integration of Birt has been released recently: https://marketplace.atlassian.com/plugins/com.kintosoft.jira.birt_viewer
