Field Configurations and Field Configuration Schemas
Chethana Hashani
Hi all,
I am bit confused about purposes and usages of field configuration and field configuration schema. Could someone please clarify me on this
Hansi
Yogesh Mude
August 12, 2018
HI @Chethana Hashani
Let say, You have different Issue types that you are using in your project and in this, you want to configure different fields should make required/optional, this can be done using field configuration. for multiple Issue types you want to do the same then you need to create multiple field configurations and each issue type then you need to associate all the field configurations into one Field configuration scheme.
The Field configuration Scheme is nothing but the collection of field configurations.
Please have a look at the below Kb for the same.
https://confluence.atlassian.com/adminjiracloud/configuring-a-field-configuration-scheme-844500805.html
Sudipta Panda
December 17, 2021 edited
Dear @Chethana Hashani , I will try to explain this. Very recently I understood by doing a fresh experimentation.
Lets take a scenario : I have a custom field named "Documentation Impact". This is a radio button field which record if a requirement (Story, or defect fix, or task for that matter any issue) impacts its product documentation. Now, I want to for all Bug issue type I want to make this Required field, but will not make it required for other issue types. This can be accomplish by Field Configuration Schema. How ? ... lets see below
Field Configuration : This is a configuration set of all filed (including custom fields) which defines at filed level at least for following options (See Fig 1).
  • Viability Control of the Field
  • Optional or Required
At my example , I have given this set of fields configuration to Field Config A
Fig -1
That means for all fields I can configure its visibility and optionality and to that set, I give a name as Field Config A . At 1 you can see the name of the field config, at 2 you can see you can tweak the configuration at field level for all fields. As I mentioned based on above requirement, I changed the Custom Field "Documentation Impact" field to Required in thsi schema (See Fig 2)
Fig - 2
At point 3 , you can see the filed is configured "Required" under this Field Config A
Now I create a Field Configuration Schema (named Field Config Schema A)which will include all issue types including a Bug type, But that Bug type in this Field Configuration Schema is following Field Config A. This will make the same field "Documentation Impact" in other issues Optional but for Bug Mandatory. (See Fig - 3)
Fig - 3
Hope my attempt of explaining help audience.
Any suggestions welcome.
Danyal Iqbal
August 13, 2018
Field configuration and field configuration schema are used to add context to a field on a per project basis.
A new custom field will be added to all projects using the screens containing that field by deafault unless, you add context (projects) to the field with the help of field configurations to restrict the field to a subset of those projects.
Register Now
