Hy, if icreate a task field configuration and i want to make some fields required but just for the Task issue type, not for the others...how do i proceed ?
Create a new "field configuration scheme" as well, and apply it to the project.
The"field configuration scheme" says things like "for bugs, use field configuration 1, for features, use fc2 and for all the others use fc7"
