Field layout contains non-orderable field
Sreenivasaraju P
September 19, 2014
we have upgraded our JIRA to 6.2.7 version. After upgrade we are getting the following message in the logs.
and the custom fields listed the in the logs are not showing in the custom fields section but are available in the database.
Any idea about this issue.
2014-09-20 11:49:28,586 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22205'.
2014-09-20 11:49:28,822 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22203'.
2014-09-20 11:49:28,822 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22204'.
2014-09-20 11:49:28,822 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22205'.
2014-09-20 11:49:28,939 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22203'.
2014-09-20 11:49:28,940 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22204'.
2014-09-20 11:49:28,940 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22205'.
2014-09-20 11:49:29,057 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22203'.
2014-09-20 11:49:29,057 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22204'.
2014-09-20 11:49:29,057 localhost-startStop-1 INFO [fields.layout.field.AbstractFieldLayoutManager] Field layout contains non-orderable field with id 'customfield_22205'.
4 votes
Ivar
December 1, 2014
We had the same issue. I found a solution, referenced here: https://jira.atlassian.com/browse/JRA-4423
Go to Admin > System > Troubleshooting and support > Integrity checker. Choosing "Check Field Layout Scheme Integrity" and run it gave me 10 errors. "Fix" took care of the situation.
The issue is about a removed custom field where the reference to all haven't been deleted.
Nexxera - Netadm
December 12, 2015
Thanks Ivar, I had same issue when upgrading from 5.1.1 to 6.4.12 and the Integrity checker works fine!
Chris Whitten [Comskil] March 15, 2016
I had JIRA Service Desk 7.0.10 and this worked for me too. Thanks!
Edmond Ho
August 12, 2016
I have the same error, but it's not related to customfields not being removed from field layout schemes, such as these system-fields:
  • Epic link
  • Epic name
  • Rank
Integrity checker did not point this out as an error. Still hunting down the cause of this error.
On JIRA 6.4.10
Register today
