Field shows as a plain text, Field configuration doesn't have renderer choice, how to change?
vitaliy zapolskyy
August 29, 2016
This question is in reference to Atlassian Documentation: How To Add a Message or Field on JIRA Create Issue Screen
I've added Message for edit field according to https://confluence.atlassian.com/jirakb/how-to-add-a-message-or-field-on-jira-create-issue-screen-759990667.html
unfortunately it shows plain text instead of table and rich formatting.
JIRA 6.4.10
Nic Brough -Adaptavist-
August 29, 2016
What 'rich text' have you added?
vitaliy zapolskyy
August 29, 2016
(i) Until deleted project can be saved for off-line
|| Operation/Project Status || Active || Read-Only || Hidden ||
August 30, 2016
Ah, wiki markup only works in the editor now.  You should find html works though, although I suspect that may go eventually.
