Field validation for a single issue type
Frank Winkler August 23, 2018
we have a custom field "Affects version(s)". This should be made mandatory for a group of projects - but only for one issue type (Bug). In workflow transitions it's easy to do this validation using a Custom Script Validator from ScriptRunner. But how can I do this when the issue is edited - Edit is no workflow transition?
I suppose this could be done using Behaviours but couldn't find the point where to put my validation script.
Thx in advance!
Frank
Nir Haimov
Hi @Frank Winkler
Yes, you can do it from Behaviours.
Admin cog -> Add-ons -> Behaviours
  1. Add new behaviour
  2. Click "add mapping" to map it to the projects you want
  3. Click "Fields" to choose the field you want.
  4. Once you choose the field you have 3 behaviours for it:
Choose "Required"
That's it
Hi @Nir Haimov,
thx for your reply. Unfortunately this would make the selected field required for all issue types. But it must be mandatory only for Bugs.
I think the solution could be a script like this (as Initialiser and at field "Issue type")
def issueTypeId = getFieldById("issuetype").getValue() as String
def affectsVersionField = getFieldById("customfield_11023")
if ( affectsVersionField ) {
 if (issueTypeId == "1") { //Bug
        affectsVersionField.setRequired(true)
    } else {
        affectsVersionField.setRequired(false)
But unfortunately at the moment it doesn't work. I'll have a look at it tomorrow.
Regards!
Frank
Nir Haimov
You are right, it will be mandatory for all,
Let me know tomorrow if your script work or not. :)
Frank Winkler August 26, 2018 edited
Hi Nir,
after some research (first I used a wrong field ID) this script works perfectly.
def affectsVersionField = getFieldById('versions')
    affectsVersionField.setRequired(issueTypeId == "1")  //Bug or not
Best regards!
Frank
Nir Haimov
Great!
glad to hear it worked out :)
Register now
