Hello!
I am trying to export Table Grid Editor custom field as a part of my issue, but the export fails with NPE. I found the reason: FieldLayoutItem that is passed to TGE custom field type and view template has no orderableField set. That causes NPE. How can I work it out?
Hi Micheal,
Can you share your template?
Which version of Xporter and TableGrid are you using?
RMRodrigues.
Here is my template: https://dl.dropboxusercontent.com/u/50925146/newTemplate.docx
TableGrid 1.19.0
Xporter 4.1.2
JIRA 7.1.4
