Fields Required Validator is disabled.
Ed Chan August 18, 2016
This question is in reference to Atlassian Documentation: How to make JIRA applications fields required in a workflow transition
I enabled the Suite Utilities module but The Fields Required Validator is disabled default and I can't enable it. When hovering over, it shows the text, "Module cannot be modified".
Any ideas?
Sara February 27, 2019
Is JIRA applications Suite Utilities a paid plugin in JIRA server?
Is there any way to use field required validator without additional add-on purchase in server?
Steve Behnke [DiscoverEquip.com]
September 9, 2016
If you believe this to be a bug your best bet is to approach support.atlassian.com, their turnaround should be much faster than Answers.
However I believe that KB article is wrong, you should have a Field Required validator out-of-the-box in JIRA Cloud now.
Are you using JIRA Cloud or JIRA Server/On-Premise?
Ed Chan September 9, 2016
Please.. someone..
