Dear Experts.
Fields of project A are visible into in project B?
For Example, I have a project named A and it has 5 fields, say name, doj, city, employment status and LWD.
And in another project B, i have same 5 fields and 3 more fields. current location, Field work and Reporting manager.
Whenever i logged in project A, it also display the fields of project B and i am not sure how this could be possible? even i have these 3 fields in column filters all are unticked but still it is available in the bar with no data.
Could you please suggest me where is the lacking? Let me know if required more inputs this.
M
Did you create two different screen schemes for your two different projects? It looks like your projects are sharing the same screen.
Check the screen schemes that are used by your projects.
Elifcan
Hello!
You should configure a Field Context.
Have a look also at Configuring a field configuration scheme
Hope this helps.
Register now
