File not found issue when trying to export CSV with all fields from filter results on Jira
Jake McAllister October 18, 2018
After selecting a filter for certain issues I click the Export drop down menu and select "CSV (All fields). I chose to delimit it with commas, then it will open another page saying File not found? When I select "CSV (Current Fields)" it does the export fine it seems. Is there a likely reason for this?
Rambabu Patina _Appfire_
October 18, 2018
Hi @Jake McAllister, Can we know what is the Jira version? A workaround in the similar issue JRASERVER-62517 might be helpful to you. Thanks.
Let's build A Rovo Agent 🤖
Save your spot
