I'm trying to install JIRA 4.4.3 WAR version to JBoss6.0.0 in my ubuntu server. I've applied all steps at http://confluence.atlassian.com/display/JIRA041/Installing+JIRA+on+JBoss+4 but when I try to deploy my war file to the jboss application server, I get the "java.lang.SecurityException: class "com.atlassian.jira.web.util.FileNameCharacterCheckerUtil"'s signer information does not match signer information of other classes in the same package" exception.
Do you know how can I resolve this problem?
Thanks in advance.
Reconsider JBoss, whilst a fine J2EE AS proper, is not supported by Atlassian - http://confluence.atlassian.com/display/JIRA/Supported+Platforms
Of course it should work inside any J2EE compliant Appserver, but there are myriad things that can crop up. Annyoying niggles like this are going to soak up your time.
If you want a WAR deployment, consider doing that under Tomcat alone. In my experience, the smaller footprint and maintainability of one-app one-container pays dividends.
p.s. I Think the Atlassian doco reference to 'Application Server' in Tomcats case is using artistic license, possibly confusing to some. Its not an AS, its a servlet container only.
Same here for me on Winstone and other container. It's a shame that it's just not portable anymore. :(
It's jira 5.2 as well.
Any others know of a java based bug tracking system around?
Same problem here with Jetty 6.
If I remove the jira-screenshot-applet jar from Jira it will start up OK.
Any ideas on what is going on?
Just for information: it is Jira 5.2-m05 (WAR), Jetty 6.1.26 on Oracl JDK 1.6.0_32
