You can sort the issues in both the gadget as the issue navigator by clicking on one the columns. Maybe that is why the sequence appears different?
The filter gadget simply shows the filter as you have saved it, so if you have not defined any ordering in your filter than the filter gadget should also display that without ordering.
Can you please re-confirm if you have meant that the order of columns and sorting followed in the "actual filter page / issue navigator" cannot be synced as it is, on to the "filter results gadget " dashboard?? Please re-confirm. If so, can you please help me in understanding how does filter results gadget work and pick up the sorting column / order? I mean which column would it first pick for sorting and how.... Let me know if my question is not clear or any other details please. Thanks a ton!!!! Smile :) -Monika
What I mean to ask is...can the sequence be maintained same in the issue navigator as well as filter result gadget,.?? in the issue navigator i CLICK on priority column to be shown up Ascendingly, can the same be shown up in the gadget as well? Can the sycn happen in such way??
If you save the filter after you have clicked on the priority column, the filter gadget will display the issues filtered by priority as well.
Bother, I can't convert that to an answer...
