Filter for all epics for all status
Mao Lee July 2, 2018
I haven't been able to find a solution for this.  Does anyone know if there is a way to write a filter to list all epics with all status (open, in progress, complete) and then be able to pull it to Portfolio?  Any feedback would be appreciated.  Thanks.
Aswin Achuthan
July 2, 2018 edited
issuetype = Epic AND status in (open, "In progress", complete)
This query should list all Epics in those status. If you want add Project = A using AND operator.
Save this filter, then in Portfolio Plan > Configure > Issue Sources > Edit Source to pull these Epics using filter option.
Mao Lee July 3, 2018
Thanks so much for the quick response.  This works!
Another question.  Your suggestion above works great.  However, when I pull the filter into Portfolio, I noticed that some projects (Epic) did show up in Portfolio.  I have one Epic -AP-81, I can see that is in the filter but it does not show up in Portfolio.  I would think that Portfolio should pull the entire filter over.  Am I missing something with this?  If you can provide feedback/thoughts.  Thank you.
Aswin Achuthan
July 5, 2018
@Mao LeeIs it displaying in the Scope list in lower part of the screen ? If it does and not in scope timeline area(top section in portfolio) check the Target Start, Target End date.
Mao Lee July 5, 2018
I clearly have the epic AP-81 but in Portfolio, all the tasks and simple tasks that are attached to the Epic are appearing without an Epic (Issues without parent Epic) section of the bottom which I do not understand.  When I click on the tasks, there is no Epic assigned to the task (see screen shot here) then when I searched for the Epic by clicking the drop down list to search, nothing found under Epic AP-81.  I compared this Epic to other working Epics and do not see the difference.  Any ideas why or what I need to change so that the Epic will show up in Portfolio along with all the tasks so the tasks don't say "No Epic"?  Thanks.Portfolio.jpg
