Hello! We are working in JSM and my team works within 2 shifts. How can I separate the total amounts for 2 shifts? For example, I want to make a report which shows me average amount of tickets on 2nd shift per day and per agent
Hello @Batrak Daria 👋
The Time in Status for Jira add-on can be helpfull.
The main functionality is to generate status time reports, but you can configure calendars according to your working hours, excluding holidays or non-working hours from the calculation.
You can configure several calendars for 2 shifts and get average amount of tickets and average time in status by Average report and also per agent by Assignee report.
Time in Status for Jira Cloud
Add-on has a 30-day free trial version and free up to 10 users.
Hope it helps 😌
Thanks! We took your add-on. Could you please help to set it?
@Batrak Daria Of course!
Here is documentation
You can also book a live demo - we'll show you the application inside out and answer all your questions.
Have a nice day 🥳
As an alternative, you can try Status Time Reports app developed by our team. It mainly provides reports and gadgets based on how much time passed in each status.
Here is the online demo link, you can see it in action and try without installing the app. For further details, you can have a look at Status Time Reports How to Videos.
If you are looking for a completely free solution, you can try the limited version Status Time Reports Free.
Hope it helps.
Hello @Batrak Daria ,
I believe Timepiece - Time in Status for Jira which is developed by my team at OBSS, has a report type that will meet your need. Our app is available for both Jira Cloud, and Data Center.
Time in Status mainly allows you to see how much time each issue spent on each status or each assignee.
The application also offers custom calendar support. Calendars can be configured based on your working hours, excluding holidays and non-working hours (even lunch breaks) from the calculation. Time in Status reports can be generated based on your custom calendars. In your case, you can set up two different calendars for each of your shifts. By selecting the appropriate calendar, you can retrieve all the reports you need from the application and easily analyze performance between shifts.
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well.
Time in Status reports can be accessed through its own reporting page, dashboard gadgets, and issue view screen tabs. All these options can provide both calculated data tables and charts. And the app has a REST API so you can get the reports from Jira UI or via REST. Also you can export the reports in to various formats easily.
Visit Timepiece - Time in Status for Jira to explore how our JIRA add-on can revolutionize your metrics measurement process. Enjoy a 30-day free trial to experience the full range of features.
Hope it helps,
Gizem
