Are you somewhat experienced with scriptrunner ? Then with the help of their documentation it should not be too hard to write a custom JQL-function script.
If you are not somewhat familiar with writing scriptrunner scripts , I think using scriptrunner for this might not be a good idea...
I can't write a script for you without knowing your environment (names of issue types, custom field names and types, …)
I read some of the documentation but i'm not too familiar with how I should write the scripts for scriptrunner but normal JQL filtering is what I'm stronger in. Could you help do a draft for the script. It would help change our workflow for our company !
It is not clear what your definition of "the last known" is, but I think this is not feasible with the standard Jira.
But as you have scriptrunner, I would create a scripted JQL function for this. The Adaptavist documentation is a quite good starter. I have built several myself :-)
