Find archived issues for project via Scriptrunner
Jakub Cieplinski
I want to know how can I find all archived issues for a given project using scriptrunner.
Helmy Ibrahim _Adaptavist_
March 15, 2022
Hi Jakub,
Here is how you can do it from a Script Console:
  1. First, get the project object with ProjectManager.getProjectByCurrentKey.
  2. Then, get all issue ids with IssueManager.getIssueIdsForProject
  3. Get all issue objects for the project with IssueManager.getIssueObjects.
  4. Finally, filter only the archived issues with Issue.isArchived.
Here's an example:
def projectManager = ComponentAccessor.getProjectManager()
def issueManager = ComponentAccessor.getIssueManager()
def project = projectManager.getProjectByCurrentKey('TEST')
def issueIds = issueManager.getIssueIdsForProject(project.id)
def issues = issueManager.getIssueObjects(issueIds)
def archivedIssues = issues.findAll { it.isArchived() }
I hope this helps!
Helmy
Jakub Cieplinski
Yes, that's exactly what i was looking for, thank you
