Find scriptrunner (behavior, fields, listener,...) associated with script files
Ha B_ May 22, 2024
Is there a way to get the information of the scriptrunner (behavior, or workflow,...) associated with a script file listed under 'Script Editor'? Basically, I don't want to go through each ScriptRunner kind/tab (behaviors, fields), open each of them and look for the file name.
I'm a newbie. Hopefully, this is the right place to get the answer.
Payne
May 23, 2024
Sure! You're on the Script Editor tab ... choose the Built-in Scripts tab and choose the Script Registry tool. Click the Run button, and once it has had a chance to run, use ctrl-f and type the name of the script you're looking for. Do that for each of the tabs (Workflows, Listeners, etc.)
Ha B_ May 30, 2024
Thanks Payne.
