Fisheye and Crucible compatible versions for Jira6.1.7?
jayasingh
May i know the compatible versions of Fisheye and Crucible for Jira6.1.7.
Jayasingh
Tiago Comasseto
June 1, 2014
Hi Jayasingh, you can follow this application link compatibility matrix: https://confluence.atlassian.com/display/APPLINKS/Application+Links+Version+Matrix
Basically if you're using JIRA 6.1.7, you can connect it with any FishEye/Crucible version 2.7.x and newer, up to the latest.
I hope it helps.
Cheers
