Based on JASON output is there a way to determine if an issue has a check-in? I can get the JASON output for a given issue with the help of below URL: but there is no info related to "source tab".
https://myjira.com/rest/api/2/search?jql=(id%3D<issue-key>)
Jo
Hello Hanumesh,
This would actually be a query against FishEye, and the REST API call mentioned in the documentation below worked for me:
https://docs.atlassian.com/fisheye-crucible/latest/wadl/fisheye.html#rest-service-fe:search-v1:query:repository
My URL was:
http://localhost:8060/rest-service-fe/search-v1/query/SVN?query=select%20revisions%20from%20dir%20%22/%22%20where%20comment%20matches%20%22JRA-1%22
Where:
The query above returned all revisions/commits/changesets that have the JIRA issue key JRA-1 mentioned in their commit message.
The Source Tab of a JIRA issue also searches in FishEye side for commits whose commit messages mention JIRA issue keys in order to list them, so the query above should work for you.
I hope this helps!
Felipe Kraemer
Atlassian Support
