Hello, i do want my sub tasks of a Feature having the same Fix Version Value than the Fix Version of the Feature...is there a way to filter all the Sub tasks of all Features with xx Fix Versions and than make a bulk change on this Sub tasks to get them all the same fix Version field ?? i do not want to do this manually
You can do this by using JIRA Misc Workflow Extensions. It provides you post function to set field value from parent (any field). Just add this postfunction to yor workflow.
Hm, if it is acceptaable for you a can help with script for Script Runner console provided by Script runner to do this.
Help us plant more trees
