Fix Versions field is empty even though my project has multiple fix Versions
Yassin
Hi Everyone,
I have a software project X with a list of Versions defined. I have EPICs and Issues in the EPICs. If i set the issue "project component" then scroll the Fix Versions select list, i do see all my already defined Versions. Now if I set the Component to None and scroll again the fix Versions select list, I dont see my fix Versions, the field is editable but no elements.
Could this be a bug in JIRA ?
PS: I have a long list of Components and Versions > 50.
Nic Brough -Adaptavist-
May 15, 2017
That sounds like you have some form of add-on or UI customisation that is breaking the system field lists somewhere.
Do you have the Script Runner enabled, or any javascript hacks in the announcement banner or field descriptions?
Yassin
I have Script Runner Installed true,
Yassin
I am using Script Runner Custom Field with the following source:
import com.atlassian.jira.ComponentManager
def componentManager = ComponentManager.getInstance()
def leads = issue.getComponents().toList()
if (leads) {
def lead = leads?.first()?.lead
if(lead) {
UserUtils.getUser(lead)
The script never failed.
May 16, 2017
I was thinking more of any "behaviours" - do you have any of those in use?
