I'm working in a multilanguage JIRA environment and after upgrading to version 5.0.4 I've found that the flash visual workflow editor has lost all label values and only shows the variable names.
At the same time when working in one language all of a sudden you'll find pieces of text (belonging to the JIRA interface) that have switched to another language.
anyone has a solution?
thanks,
Jacques.
It looks like a Plugin problem to me... Have you installed any language pack plugin? Check if you have any plugin without being updated.
And the problem you mentioned about other languages it's a very common bug, here it is a question about this:
