  • Community
  • Products
  • Jira
  • Questions
  • For Issue type = Bug, when we perfume close action I would like to populate two additional text fields so that root cause and preventive action are filled before closure of any live bugs. Can someone help me with steps? Thank You!
Anizkhan Kaleelrahman July 30, 2015
Alexandra Topoloaga
August 14, 2015
You are not on "edit mode". You will need to click "Create draft" (see the yellow band from the top of the picture 2). At the end, after saving the postfunction, you will need to publish the draft. Sorry I've missed it smile
Alexandra Topoloaga
July 31, 2015
This is a thing you can do very easy using JJUPIN plugin. All you need to do is to add a postfunction on the desired transition in which you populate the fields like this:
customfield_x = "value1";
customfield_y = "value2";
The documentation of JJUPIN can be found here and more examples of post functions are here.
Hope this helps,
Alexandra
Alexandra Topoloaga
August 21, 2015
Well, you will need to use the ids of the custom fields you want to set. I used 10001, 10002 and 10003 as an example. In order to get the ids of your custom fields, go to "Custom fields" page, find the custom field you want and click "Edit". The id will appear on the address bar:
image2015-8-21 14:4:14.png image2015-8-21 14:6:13.png
In the example above, 10500 is the id of the custom field, so I would need to use customfield_10500.
Also, I guess that the value you want to set is not "value1", please update this as well. smile
Alexandra
Anizkhan Kaleelrahman August 20, 2015
Thank you @Alexandra Topoloaga, i can edit now, this is very helpful,
However after pasting your code, and clicking check "It throws following error", is it still fine to publish the below code?
if (issueType == "Bug") {
customfield_10001 = "value1";
customfield_10002 = "value1";
customfield_10003 = "value1";
image2015-8-21 17:38:17.png
Anizkhan Kaleelrahman August 14, 2015
Awesome!
Thank you for the clear steps, I am trying the steps, however on the step 2 my "Add post function" is disabled, do you know how to enable it?
1)
image2015-8-14 18:36:57.png
2)
image2015-8-14 18:38:30.png
Alexandra Topoloaga
August 13, 2015
You are on the wrong screen. At the moment, for your request, you do not need to configure JJUPIN (anyway, the default configuration is all right). All you have to do is to upload JJUPIN into your add-ons and add the postfunction from the workflow screen on the transition wanted. Please notice that you can close an issue from many states (you can go directly from open to closed, from in progress to closed etc).
All you should do is explained, step by step, in the pictures below:
1.image2015-8-14 10:54:30.png
2. image2015-8-14 10:56:20.png
3.image2015-8-14 10:56:42.png
4.image2015-8-14 10:57:33.png
Now, when the transition is triggered, the fields will get populated.
I hope it is clear now smile
Alexandra
Anizkhan Kaleelrahman August 13, 2015
I am trying to configure JJUPIN plug in, however it is asking for following info, where i can find it?
Kepler parameters for the JJUPIN plugin
Configuration values for plugin : jjupin
Default Program Name
Default comment
Default filename
Default directory
SIL Web Service enabled?
SIL Web Service Run As
Also i couldnt see "(k) SIL Post-function"; i see only emails, sil.aliases, sil.properties like below screen.
Sorry for such basic questions, this is the first time i am trying to install a Plugin.
image2015-8-14 15:49:59.png
Alexandra Topoloaga
August 13, 2015
Hi Anizkhan,
I am glad you found my answer helpful.
First, you have to create a postfunction on the "Close issue" transition. You can do this by editing the workflow. You will have to choose "(k) SIL Post-function" and put the script you need there. The script should look like this:
	customfield_a = "value1";
	customfield_b = "value2";
	customfield_c = "value3";
Click add, publish the workflow and that's all. smile
Thanks a lot for your reply, I just bought JJUPIN, could you please help me with step by step procedure to do it.
I need to populate 3 text fields (mandatory) when Type is “Bug” and action selected for transition = close.
Please help me with the steps.
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
