For certain user a particular status should not be visible
OMom2019 February 19, 2020 edited
Hi Team,
for certain user last status alone should not be visible. If I put some condition it does not work. Kindly help.
Ganesh Babu
Hi @OMom2019
You can actually restrict single user, or with respect to project roles, or group of users to perform the action.
In that case according to the need you can use the condition to the last transition to last status.
Here you can restrict the transition to only particular user, or by project role or by group.
Hi , THanks for the reply. But for the last status I did not set any transition in that cas how to make invisible the last status.
Ganesh Babu
Hi @OMom2019
So you mean to say that you have global transition for the last status?
Am i right? If that is the case then i think its not possible to restrict without having the transition to the last status as you mentioned.
Ganesh Babu J
Richard Bouchacourt
Put theses users on a Project Role and add a Condition to the Transition of the last Status.
The Condition : User Is In Project Role
Richard
Register today
