For issue https://itrack.web.att.com/browse/IPLAT-5780, that was closed. A resource that is a member of the project (not an Admin) was able to re-open the issue even though they were not the Assignee or the Reporter. Does this have to do with the workflow? Can it be changed so that it cannot be re-opened by someone else and only by the Reporter or Assignee?
Hello @Vara Prasad
The ability to change a status for an issue is impacted by a number of factors:
Some questions that you need to ask in order to design the right solution:
can I limit issues being re-opened only by those that are Assignee or Reporter? Thanks.
Yes, it is possible.
Without seeing the details of the workflow I am not able to tell you all the exact changes you need to make.
In general terms:
1. If there are Global transitions to the destination statuses of concern, those will have to be eliminated and replaced with specific transitions from other statuses to the destination statuses.
2. On the transitions from the "done" statuses to the "open" status that you want to allow only the Reporter or Assignee to execute, add Conditions to the transitions. You would use the Only Reporter Condition and the Only Assignee Condition, and select the Any of the following conditions option.
Hello @Vara Prasad
Were you able to address your need with the information I provided? If so, please consider clicking on the Accept Answer button to mark your Question as Solved.
If you still have questions about this solution, please let us know.
