is there a way to forbid setting an epic/story done if the issues in the epic/story aren't done?
Regards, Ahmet
Yes, you add a "subtasks not closed" condition to the transition(s) leading into "done" status in the workflow. This is a function built into standard JIRA, and it can check any status, it's not just limited to "sub tasks are done"
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
