Is there an example of the CSV file thta can be uploaded as a template?
Hi Lenny,
This link will walk you through setting up and importing a CSV file. You can select your version in the top right corner.
Hope this helps,
Danny
I am looking for a Excel Spreadsheet specific example. If there is a csv file that can be displayed here, that would be helpful. I am having trouble importing the Test Steps. Importing the file is creating Test Cases for the Summary field for each Test Step. And the Test Steps are blank in the a Test Case (issue type) in JIRA.
Lenny
Hello Lenny,
Which test management plugin are you using?
Marcin
I am looking to import the Test Steps to a specific test Case as well. How do I accomplish this?
