Format to restrict certain values of single-select drop-down and cascading drop-down based on roles
Prayuja Patil
If 'product' is my custom field and 'xxx','yyy','zzz' are options for it. And p1,p2,p2 are my project roles. Then, it should work like this
For p1-----> 'xxx','zzz'
For p2----->'zzz','yyy'
For p3----->'zzz'
I want groovy script for this.
Roland Holban (Adaptavist)
April 13, 2018
Try this. Of course you need to replace "sample select field", "p1", "xxx", etc. with the appropriate names.
import com.atlassian.jira.security.roles.ProjectRoleManager
// Project associated with the issue
def project = issueContext.projectObject
// Current User
def user = ComponentAccessor.jiraAuthenticationContext.loggedInUser
// All the roles for this user for this project
def userRoles = ComponentAccessor.getComponent(ProjectRoleManager).getProjectRoles(user, project)*.name
// The select field
def field = getFieldByName("Sample Select Field")
if (userRoles.contains("p1")) {
field.setFieldOptions(["xxx", "zzz"])
} else if (userRoles.contains("p2")) {
field.setFieldOptions(["yyy", "zzz"])
} else if (userRoles.contains("p3")) {
field.setFieldOptions(["zzz"])
Help us plant more trees
