Formatting for 'blocks' of text on multiple lines not getting applied properly when using Wiki Editor
Julian Flatt
When using the Wiki Editor if you select several lines of text at once and select bold, underline or italic the wiki markup isn't getting applied correctly.
For example if you have 4 lines of text like this :-
line1
line2
line3
line4
and then select them all and select B for bold the following results appear :-
*line1
line2
line3
line4*
This doesn't cause the text to become bold but just changes it so that line 1 has a * at the start and line 4 has a * at the end.
The proper markup should be with a * at the start and end of each line :-
*line1*
*line2*
*line3*
*line4*
Similar issue occur for underline + and italic _
The obvious workaround is to format each line separately but just wondered if there is a known fix or any plans to get the formatting working when multiple lines are selected.
4 votes
Pawel Jarosz
November 14, 2016
Same here, cannot believe that in 21st century we still run into that kind of issues o_O
Justin Grant March 27, 2015
We ran into this too. Lack of good support for rich-text editing is very frustrating!
Dylan Nicholson December 20, 2018 edited
For "pre-formatted" you actually need to use the [+v] button on the RHS (labelled 'Other') and select "preformatted". That adds the following tag:
{noformat}
which can then contain multiple lines before a matching {noformat} at the end.
Alexis Dray
this STILL doesn't work, and it results in long comments looking amateurishly authored and unprofessional or else, 20 minutes spent adjusting, saving and viewing
TINYMCE has had this since 2009...
if markdown is so inflexible it can't be used with intuitive tools, switch to a different rich text editing experience
//rant
Gil Edri
March 7, 2018
+1
At least, I'd expect the Bold command in the toolbar to be aware of this and add the *'s on every line.
el_schalo June 6, 2017 edited
