Formatting issues with Export to PDF function
loretta rinaldi
Several issues with this feature: 1) task list checkboxes, checked or unchecked, do not display properly, 2) cannot choose portrait or landscape - everything is portrait style, 3) table columns have a mind of their own as far as how they fit on the PDF page.
Can anyone offer some advise on any of these issues. I looked at PDF stylesheets and PDF layout in Confluence Admin, but those do not seem to be what I need for these 3 issues above. Thanks in advance.
Steffen Heller
March 31, 2014
What do you want to know about 3) table columns?
Christoph Philipp
March 26, 2014
I can help you with the protrait/landscape problem.
You will not be able to choose, but you will (at least) be able to change
@page
 size: 210mm 297mm; /* Sets the page size */
 margin: 1.5cm 1.5cm; /* Sets the page area for content */
 padding: 0.5cm; /* override default that breaks @bottom alignment */
If you switch the numbers after "size:" you can switch from portrait to landscape (her it is A4)...
best
chris
loretta rinaldi
Thank you! I will try this!
Chris Armstrong March 24, 2014
I also have this issue with the checkboxes.
