Found multiple JSESSIONID cookies, when rendering link to screenshot applet page
Atle Rinvoll
Hi
I am running Jira 5.2.7 behind Apache and i've started to get lots of the following messages in the log:
/secure/IssueAction!default.jspa [jira.web.util.CookieUtils] Found multiple JSESSIONID cookies, when rendering link to screenshot applet page. You may have another Java webapp at context path '/' (in which case this message is harmless), or there may be a problem in IE attaching the screenshot via the screenshot applet.
Everything seems to work fine but the message is annoying.
Is it fixable? I presume it has something to do with tomcat and apache?
If not, can I turn off this logging?
\Atle
Renjith Pillai
April 8, 2013
Jositz, Michael (Allianz SE) May 2, 2013
We also have loads of these messages in our log. Can we do anything to get rid of them? We run JIRA 5.2.10.
Bogdan Calmac
I've encountered the same issue and after inspecting the cookies I noticed that they are just for the current browser session. A browser restart is enough to get rid of the log messages.
Middle Ware April 7, 2013
Hi there, I'm in the same situation, did you have any luck solving the issue?
Atle Rinvoll
No, I haven't. It seems to work ok so I haven't looked more into it.
Middle Ware April 8, 2013
Thanks for the reply, I'll try and look around a bit more, wish me luck.
Learn more
